kaupinator
- Jun 21, 2010
- 20
I have a 1969 85hp evinrude electric shift. Two questions 1. When running at ide I can take the bottom plug wires off of the plugs and can not hear any difference in the motor. If I pull of either of the top spark plug wires the motor dies instantly. It seems to run pretty smooth when the throttle is opened up. The main reason I am asking is I had the boat out 2 weeks ago and it ran fine. Last weekend I took it out and could not get it to stay running. I had to start it using starter fluid and then it would die when put into gear. I got it home and in the process of cleaning the carbs with some spray cleaner realized that the battery was almost dead. I charged the battery and now it stays running and idles ok. 2. Can a weak battery cause the motor to not stay running at idle?
