PLEASE HELP!! We hit rocks n our boat is broke!! Mercruiser 4.3 Alpha One
shaysdaddy1
we have our first boat and got in over our heads in a lake with too many wakes and ended up too close to the bank. actually pretty much on the bank. when we tried to pull it out, we hit rocks. we tried to get out by giving it more gas. something snapped :eek: and now our boat wont go. we give it gas and it just revs up but no movement in the prop. the prop is all bent up. we keep getting the shear pin answer from everyone but cant seem to even locate it on our boat. We have the whole lower half off and dont know what to do now. not exactly in our budget to go to a marina. any ideas of what could be wrong???
Pokertrampp
Re: PLEASE HELP!! We hit rocks n our boat is broke!!
Year, Make and Model of motor/outdrive will be needed before anyone can help.
bigskiohio
Master Chief Petty Officer
you should have replaced the prop first. now you are in above your head.
Mark42
Yep, make, model, hp of motor helps.
Might be a shear pin, might be a spun prop, might be a broken gear case.
While you are saving up for the parts to repair the damage, sign up for a boaters safety course. It will help you avoid these kind of situations, as well as basic safe boating.
shaysdaddy1
mercruiser 4.3 L inboard alpha one
jtmarten
Since you have the lower off, spin the driveshaft by hand, see if the prop shaft rotates.
And ........ post engine/drive specifics, we'll be able to give better assistance.
shaysdaddy1
it does not rotate. what is engine drive specifics?
shaysdaddy1
mercruiser alpha one 4.3 L
jtmarten
Re: PLEASE HELP!! We hit rocks n our boat is broke!! Mercruiser 4.3 Alpha One
We need year, engine model, and SN if the sticker is still on it the valve cover, and the drive type, ie Alpha 1, Bravo, Volvo, OMC, etc.
Example: see the bottom info in my post.
shaysdaddy1
drive unit number is 0b875292. sn ob897571. alpha one year not sure. we were told it was brand new when we bought it in 09 but looking at the insides of it it doesnt look brand new. how can i find the year?
jtmarten
Hit up the adult's only section too. It has links for the mercruiser shop manuals for your engine and drive. If your boat is older than '91, you should have an Alpha 1 gen 1, newer than '91 it should be a gen 2 (I think '91 is the change yr for them).
shaysdaddy1
boat is an 88 thundercraft but the motor was replaced and im sure its newer than a 91
jtmarten
As long as the transom assembly, etc is original, it should be a gen 1.
shaysdaddy1
ok so what should we do?
nola mike
if your prop shaft isn't turning when you spin the drive shaft (and you're in gear), you need a new lower unit.
180shabah
Have someone hold the shiftlever to either side while you spin the prop (easier than trying to turn the shaft) by hand. Does the vertical shaft spin?
Pokertrampp
After you get it repaired, you may want to invest in a chart or two so you will know where the hazards are. also maybe a boating saftey course.
