help...prop shaft problem
markiicentury
ive got a 1971 mkii that i bought in jan 2010. this boat looks like it just left the factory. well today was the first time i put it in the water. after running it for about 20 minutes the prop shaft came out hitting the rudder bending it. now i must get divers to locate the missing shaft and prop. does anyone know where i can locate some new parts and why did this happen? thanks for any help steve
79arabian
Re: help...prop shaft problem
The key must not have been inserted into the shaft coupling that mounts to the transmission.
As a back up you can purchase a 2 part coupling that gooes around the shaft and has a bolt on bolt ends. Picture a doughnut cut in half .
this should be positioned so if the shaft comes off the coupling it wont travel more than a 1/2".
smclear
A&A Marine @classicboating.com will be able to replace all lost parts.
