Re: stalls after a half hour
some thoughts...
rotor cap bad, could there be a crack in the plastics in the distributor or if its points the temperature rises and they wont close due to metal bending under temp stress, under cowl temp to high, maybe impeller blades bad and heat buildup in the head is undetectable because the hottest water isnt being moved past the temperature sensor resulting in overheating, the coil could have leaked out all its oil and it overheats, runs after it cools, the exhaust leak is building up in the compartment and its breathing co2 and stalls, pinhole in fuel line(sucks air), bad connection at fuel fittings, debris rolling around in tank rolls into opening when in operation and falls back after stall, bad gasket in carburetor, water in fuel is probable, mechanical fuel pump bellows cracked, overvoltage issues with voltage regulator in alternator, oil pressure drop due to worn bearings warming up/excessive clearance causing a shutdown sequence, could be a bad wire somewhere between fuses/starter/keyswitch/safety device (connections fail at different temps and torques)
it could be a combination of these or many things...test for everything you can think of and eliminate the things that are working. what does it sound like when it dies, quick or slow, intermittent firing, skip n' die, odd noises squeaks, runs backwards?
tell us about the fuel you pumped in to it...ethanol?(bad)...additives?
does the fuel gauge work- what level is it at?
compression test? oil pressure readings?
more input!
