Baha Cruisers
commander315
Is anybody familier with Baha Crusiers? I know they are more geared toward fishing and are apparently not designed to be fancy or stylish. However, Why is that a 29 Wellcraft has a max hp of 600 when Baha 300 has 450. Is it just lighter or is it a cheaper design and brand of boat? Im very curious as to their quality and their prices (Especially the 300 GLE)
Lrider
Re: Baha Cruisers
Somewhere I have seen the calculation for determining the weight a boat can carry, it look pretty straight forward.
Based on the estimated weight of both boats, there is about 1400 pounds difference which could allow for the extra weight of the bigger motors
That is an Engineers view point :D there actually might be someone out there that knows the truth :p
2010 Wellcraft Scarab 30 Tournament
* LOA : 30'2"/9.19 m
* Beam : 9'2"/2.79 m
* Dry weight (approx.) : 6635 lbs./3010 kg
* Fuel capacity (Gas) : 288 gal./1099 L
* Shaft length - Twin : 25"/.64 m
* Water capacity : 13 gal./49.21 L
* Max power @ prop : 600 HP/447 kw
* Deadrise : 23 degrees
30 ft Baha Criuser GLE
LOA 30? 0?
Beam 10? 6?
Dry Weight 8000 lbs
Cockpit size 115 sq ft
Standard Fuel 244 gallons
Deadrise 15 degrees
Waste 16 Gallons
Water 30 gallons
Base Power 370HP IB
T/225HP OB
commander315
Re: Baha Cruisers
LOA 30? 0?
Beam 10? 6?
Dry Weight 8000 lbs
Deadrise 15 degrees
Waste 16 Gallons
Water 30 gallons
Base Power 370HP IB
T/225HP OB
The only thing wrong with this is that the scarab tournament is a center console. (Wo a cuddy) The Baha 300 gle is an express cruiser with a cabin and a full pilot house
Lrider
Re: Baha Cruisers
Aye I noticed that, however I went by mfg and length and 600 on the wellcraft
he was pretty specific with the baha ha ha :D
I really like the wellcraft but think I will get a sailfish
commander315
Re: Baha Cruisers
Idk what to do. I want a 08 Wellcraft 290 Coastal, I want a new Chris 29 Catalina Express, Maybe this Baha 300 GLE, and maybe this left over 08 Wellcraft 35 Scarab Sport that i could get for crazy cheap!!(MSRP=$210,999, Asking price at dealer= $109,999!!!) I have no idea which way to go. Another option, of course, is to keep what i have.....what do I do?????
bcons
Re: Baha Cruisers
I was talked out of buying a 30' baha sedan 2 yrs ago, by both the marina, & a surveyor. I was told they had TONS of problems with hulls, Stringers, and overall hull integrity.
The particular one I was looking at appeared to have several repair attempts made at fixing structual problems, and all had failed.
seabob4
Re: Baha Cruisers
15 degree deadrise for the Baja Cruiser VS 23 degree for the WC. There's your HP differential right there. The flat bottom of the Baja will just become a water pushing pig if you throw more HP at her...:eek:
