Can you tell the approximate age of this outboard?
mogfisher
Hey guys. I know you probably cant tell me much from this picture but for now it's all I've got. I was just wondering if you could tell an approximate age by it's looks. I mean like is it late 70s 80s etc. I may purchase it as a fixer for short money. Owner says low comp on one cyl. He doesn't seem to know much about it but before I head over to look at it I was just wondering if y'all migh know how old it might be. Thanks in advance!
Adam
ry%3D400
Mi duckdown
Re: Can you tell the approximate age of this outboard?
Got No pic. What, no serial no, HP. Low compression???
mogfisher
Sorry. Not sure why the pic didn't work but it should be good now. Its a mercury 25 hp and the seller says it has low compression on one cylinder. Any ideas? Is this the kind of motor that doesn't have a removable head? You would have to hone/bore through the crank side if that's the case, correct? Thanks!
BassnKY
If you can get the serial number, the first thread in this post can give you the year.
mogfisher
yeah, I know. Thanks though for the heads up. I don't have the serial. I was simply looking for a ballpark before I went to see it. The seller doesnt really know or care much. Once I go see it I can see the serial, but I won't be able to look it up on the spot. I saw the thing about blue band vs brown vs red. Not sure exactly what "band" this would be. Its got a red stripe but the red band motors are older than what this one looks like.
daveswaves
Ensign
Its a mid 80's the serial number will tell the exact year. It should have a removeable head, not like the inline 6s .
SeaKaye12
You're correct; that motor is newer than the ones where the red band/blue band rules would apply.
I would guess from looking at the cowl that it's a late 80's or early 90's....
Doesn't really matter much; although I understand that you'd like to know.
The condition means way more than the age.
Chuck
mogfisher
That's all I was looking for. Thanks guys. I appreciate it. I think I'll probably pick it up. Maybe I'll print out the ser# sheet and bring it with me to find out for sure. Guy wants 200 with controls. I figure that's decent. I'll either fix it and rig it to my jon boat or fix it up and sell it. I really just want some practice for when I rebuild my 150 HP XR4 for my bass boat.
Mi duckdown
Was that motor in a fire? All the paint is all bubbled
Jacket4life
I think it's sitting in the rain, I think that's water, not bubbles on the paint.
ugadawg187
I just noticed what you were talking about with the paint. If you dont look at the pallet its laying to see that its wet & thats water on the motor it does look like bubbled paint.:D
Jacket4life
Oh, and to address the original post, looks like a mid to late 80's to me. Low compression indicates piston problem in general. Most common reason is running lean/improper oil in fuel. Since you want practice anyway, $200 is probably not TOO badd. Since you're getting the controller and cables too, I could see taking it on for that.
mogfisher
Ha. I see what you guys mean about the paint. The picture I have is much larger and you can see they are water drops. It's been raining here for days. Thanks for the input. I might go see it today and we'll see how it goes.
