4.3 Leaking on the front
tgjohnson1
Can someone point me in the right direction. I have a 4.3 gm mercruiser that is leaking fluid on the front between the head and the intake but only when under a load.
Bt Doctur
Re: 4.3 Leaking on the front
Can you tell us what kind of fluid?
tgjohnson1
Since my first post, I have pulled intake and head. The gaskets on either were messed up. I can see where it looks like oil was going under the gasket.
Bt Doctur
The front and back under the manifold are RTV Black silicone.Clean block and manifold with acetone, Run a 1/4 inch thick bead ,carefully set manifold in place, start BUT DO NOT TIGHTEN the intake manifold bolts.Let cure overnight, now torque to specs.
tgjohnson1
Thanks. Should i do any thing to the head gasket at the top where it meets the intake?
Bt Doctur
The head gasket is under the heads , no access by removing just the intake.
