98 sea doo speedster
BLC
Not sure if this belongs here or not but, I have a chance to pick up a 98 sea doo speedster. It is in nice shape but the jet pump is not working. Are they expensive and hard to fix. Do they require any special tools to fix. Or would it be fairly straight forward procedure with a maintenance manual. Any help would be apreiciated.
bigdaddypt
Re: 98 sea doo speedster
What exactly do you mean when you say "the jet pump is not working"? It could be something as little as a wear ring needing replacement, to the entire drive needing a rebuild due to seized bearings.
BLC
Not sure, I will contact the seller and get back here with the answer.
