tilt trim
tulsatom
1983 johson 115
tilt motor wont run relay clicks when I hotwire motor does nothing
how do I take the motor out I know about top pin but not the rest?
ezeke
Re: tilt trim
Remove the thrust rod.
Lift the motor and engage the trail lock.
Remove the blue and green wire from the connector housing.
Pull the clip and remove the tilt cylinder pin.
Remove the three screws from each side.
Tilt the unit and pull the unit from the transom brackets, pulling the control cable through the bracket.
tulsatom
Re: tilt trim
thanks guy I am new at all this the motor seems stuck,boats been sitting long time so I am going through everything
tulsatom
Re: tilt trim top pin
ok now the motor is almost down how I get the top pin out?
ezeke
Re: tilt trim
Turn the manual release two turns and raise the motor by hand.
tulsatom
Re: tilt trim
how does the small switch on tilt trim wire it looks like a safty switch switch
