Motor ID
topkicke8
I have a motor I can't ID. The only numbers i can find on it is on a small round disc on the top left of the motor and it is not real clear. It appears to be 55EI76E or 55EL76E. There is also a M in a small square. Above the number.
topkicke8
Re: Motor ID
Thanks for the help. I thought it was a Johnson. Again, Thanks!
Joe Reeves
Re: Motor ID
Heh, yea...... it's a Johnson, sorry. I was answering a few other questions and got side tracked.
topkicke8
Re: Motor ID
Thanks again Joe I hadn't done anything to mess anything up, so no harm. Hey is it absolutely necessary to use a outboard motor oil or will any good quality 2 cycle oil work. I ask because I have a ton of 2cycle oil but none. is outboard 2 cycle
