beaverpilot98
- Jun 5, 2010
- 3
1976 evinrude 6hp
A little history, bought this motor used, always had good top end but idled poor. Had a mechanic put a carb kit in it a couple years ago, still had idle troubles. Haven't used much in the mean time, decided to try to get her idling better this year.
Running in barrel in driveway. Was working on poor idle performance. Had it idling pretty good after installing new fuel pump (disassembled old pump and found parts missing), installed new plugs, removed, cleaned and set low speed jet, fresh gas 50:1 in cruise-a-day.
Anyway...I had the motor idling pretty darn good. Then I revved her up in gear and she starts to go good but slowly bogs down, doesn't stall , just seems to bog out. If i take of the cowling, it runs top end no problem? I was thinking need to redo carb, possible main jet varnish etc, etc BUT it runs fine with the cowling off? I did some searching on the forum, heard a few mentions of exhaust leaks under cowl? any thoughts?
