Water cooling problem?
wjmacca
Hi, I have an Evinrude fisherman Numbers GR74C & A121958.
Runs OK but appears to have no water circulation. Outlet on leg has no flow of water out. Have run wire up to check for blockage etc. made no difference.
what is required to replace impeller? Regards Macca
F_R
Re: Water cooling problem?
That would be a 6R74C. To access the water pump:
1. Remove spark plugs, and shift to forward gear.
2. Remove the 4 bolts holding the lower unit on.
3. Slowly rotate flywheel while pull lower unit downward. There is a pin that has to come down through a slot. When it aligns, the lower uinit will come down a bit more. STOP turning the flywheel when it does, and don't turn it any more till motor is reassembled
4. Now look in the gap above the lower unit. You will see the brass shift rod connector. Completely remove one screw.
5. The lower unit is now free to come down and away. Note the position of the pin so you can put it back the same way for reassembly. The water pump will be right in front of you. You do NOT have to remove the pin. Just slide the shaft out once you remove the pump screws and housing.
6. When you go to put it back together, use a flashlight to peer in there and make sure the notch in the shift rod is EXACTLY aligned with the screw hole in the brass connector before installing the screw. If the screw rubs on the edge of the notch, it will wipe the threads off and then the screw will fall out. But never at dockside--always 5 miles away from shore.
wjmacca
Thank you sincerely for your assistance with this matter. will get working on it and advise my success rate. hopefully good.
regards Macca
wjmacca
F R
where does the return for the water flow come out? and what sort of volume should there be?
is it via the outlet 1/2 way up the leg on these motors?
sorry to appear so dumb but after replacing impeller carefully as per your advice does not appear to be squirting out any surplus water
Regards Macca
Andy in NY
the water that it pumps through will come out various places on the lower unit, as well as the exaust in the prop.
