WestCoastPete
Thread starter- Joined
- Jun 3, 2010
- 8
I just a purchased a 1980 Bayliner Contessa Flybridge 2850. It has a single Volvo Penta GM 350 Block casting number 14010207. I don't know much about the Volvo outdrives but I was told it was a 280. The OD has a problem where it does not lock in place, while in reverse and drive pulls out of the water when rpm is higher than idle. The upper unit cover is also missing where the shift linkage is exposed to the water. I bought a used Volvo 280 that was mated to a GM V8. The person that told me I had a 280 may be mistaken because the unit looks more like the SP model. The top cover is flush with upper unit where the linkage cover mounts. The 280's top cover extends rearward a couple of inches.. The part number on the OD on the boat is 875672 and the part number of the used 280 I purchased is 380678. My questions is, Will the 280 mount right inplace of my existing SP outdrive? and is there anything else I should be aware of. I have a picture of the drive still in water and the used 280 replacement unit. I thought I had attached the pictures but do not see them on the post. Any help is appreciated.
