Best service manual to buy.
lakefisherman
Re: Best service manual to buy.
Looks like they don't have them for my year.
2003, 9.9 hp Johnson, 4 stroke.
wilde1j
Order from any BRP Evinrude dealer.
bigmoe
Why not a seloc manual? I just ordered one. Should I return it?
wilde1j
Most around here have no use for any of the third party books. Way too much irrelevant info and not all the info you need.
eavega
You really need the OEM manual to do work on your motor. That having been said, it is nice to also have the Seloc manual simply because they do explain things a little differently, and may even have pictures that you can use as a reference when doing repairs. I have found that if you can only have one, you need the OEM manual. If you can swing having both, its to your advantage.
-E
rattlin
Neither. Both are worse than the other.
Get an OEM Service Manual reprint from www.outboardbooks.com
Thanks so much for that link! I've been hunting my misplaced OEM factory service manual for months. Local dealer only carries Clymer version and says OEM is no longer available. About 60% more expensive at that site, but worth it if I can't find mine soon.
blimp
ebay is a decent place to look too.
kenmyfam
Realistically the OEM manual is the only way to go.
