starting motor question
hardiek
i am restoring a 1994 four winns and it currently doesn't have a throttle (which I am replacing) and the key cabling to the starter is currently disconnected (which I plan to fix soon).
I am currently working on the motor. What is the best way to start a motor temporarily without a throttle and ignition key? Thanks.
Kevin
Re: starting motor question
Ayuh,... What motor, by Whom,...??
hardiek
OMC Cobra 5.0 195HP 1993 Ford.
alien4fish
I would disconnect the electrical harness that goes to the top of engine.
Find the water intake hose that runs TO the water pump from the transom and put a garden hose to it or you can use muffs to out drive BUT MAKE SURE YOU HAVE FRESH WATER FLOWING THRU YOUR BLOCK AT ALL TIMES
make sure you have a good Ground from the battery to the block.
make sure you have a good connection to the starter from positive HOT of the battery to the postive HOT to the starter.
connect a remote starter button to the hot side of the starter and then connect the remote button negative to neg. side of the starter. WHEN YOU HAVE DONE ALL THAT
Now run a wire from the HOT side of the battery to the HOT side of the coil make it easy to disconnect if there is an emergency turn on the water so it is passing thru the motor and down and out of the out drive. And push the starter remote button and see what happens....................the motor should fire and begin to run or fart or turn over and do nothing
but that should get you in the right direction
hardiek
thanks for the info. Dumb question for you. How do you turn it back off once it is running?
thanks.
kevin
alien4fish
to turn off the motor simply disconnect the wire from the battery going to the coil the motor will die
but make sure you get the polarity right postive+ and neg.- you dont want to fry anything, that why I say disconnect the Harness at the top of the motor.
Have fun:D
alien4fish
p.s. do search on my posts here and you will see a thread on a repower that i am currently doing the I have some pix posted to help give you an idea of where things are....................let me see if i can post some up here on your thread
