Howdy Folks. Im the proud new owner of a 14 foot Starcraft with an 18hp Evinrude Fastwin (1973) and new to the forum. Ive been doing a lot of reading on here and been getting lots of great ideas on how to fix up my boat and motor. I figure its my turn to post and ask a few questions. First off I took the motor out when I first got it and it ran like trash. All the poping and sneezing you can imagine, then a violent shutter and it wouldnt start. Got home and found the flywheel key broke. Ordered a new one and while I waited...
1,Cleaned and re-built the carb
2,Cheked compression 1 Cyl 124psi 2 Cyl 122psi
3,Took head off, pistons and cyl walls look good
4,Cleaned and set points
5,took intake manifold apart and leafs and all look good.
6,took fuel filter apart and no holes in diaphram
7, took lower unit off unplugged all the blocked holes and replaced gear oil
So I got the key replaced it and hooked the motor up to the garden hose and it roared to life ran much better then before. Though not perfect. 1 of the coils looks old and I can see a slightly weaker spark. So here is the bad part I took it out to the lake and it wouldnt start. No spark. Took it home and the flywheel key was broken AGAIN!!!!!!!! So I guess my question is what could be going wrong to make the key break? The flywheel was tight. Does it need to be gorilla torqued? And second will that old coil with the slightly weaker spark make a dramatic diffrence in the preformance of the motor? I plan on replacing it anyways but just wondering. Thanks for any help
