Figure this one out and I'll buy you a beer!
Fed
Re: Figure this one out and I'll buy you a beer!
How does a loose connection pop a breaker unless the connection is on the breaker and the heat conducts into the breaker.
Short circuits and overloads pop breakers.
scutly
loose connections can cause short circuits
pine island fred
I am with FED on this one. A loose connection will cause less current flow, not more. The problem was disturbed while he was isolating the different circuits. Also would not be the first time I saw a circuit breaker degrade and would not pass the rated current. Especially around salt water. regards FRED
