sailhard
Thread starter- Joined
- Sep 18, 2007
- 15
This is a strange one.
Last fall this ( usually VERY reliable other than a few hiccups ) motor started giving me problems.
While runnning full throttle, the motor made some higher pitched noises and stopped short as if it were seized. ( motor weep holes were dribbling fine) I waited a while and restarted it but under load the same thing happened. the starter could not move the "stuck flywheel. If I let it sit for a bit, it would unstick itself and spin OK, idle fine but stick under load.
I brought it to an outboard guy last fall , and he said he replaced some parts in the fuel pump, ran it in his tank and said it was a great motor. I'm not sure what else he did, but it seemed to idle and run much smoother, but I never tested it out at sea.
So I finally got the boat out this season, it started right up great, I ran it at low speeds for about an hour and the damned thing stuck again. This time it would not come unstuck.
I removed the plugs and I can manually turn the flywheel backwards, but only turn forwards a few inches before sticking again. ( in any gear )
Any insights? I have a shop manual but it doesn't describe this symptom....
thanks.
thanks.
