Going to 24v from 12v TM
augnmike
I am thinking of going to a 24v TM but I wanted to keep my 12v TM which still works fine as a back up in case I bust my main TM. Can I do that and if so what will it take? I am a bowfisherman so the TM's really take a beating.
mikphilips
Re: Going to 24v from 12v TM
You probably have two 12v batteries wired in series to feed the 24v TM. I have a similar arrangement and I have tapped the first battery in the 24v set to provide 12v for my boat's electronics. Do you have a third 12v battery wired to the engine? If not, be careful you are not draining the battery by TM that you need for starting.
Silvertip
You can easily do this but you will need a three terminal receptacle up front and both motors would then need to have three terminal plugs even though only two will be used. Leave the 24 volt system as it is at the battery end. The new three terminal receptacle will have red, orange and black wires on it. Connect the 24 volt system to the red (positive) and black (negative) terminals. On the 24 volt troller, add the new three terminal plug using the 24 volt (red and black) terminals.
Now for the 12 volt system. Run another wire via a circuit breaker, from the positive terminal on the FIRST battery (the battery with the black ground wire attached) to the terminal that has the ORANGE wire. If you now use a voltmeter to check the receptacle, Red to Black = 24 volts. Orange to black = 12 volts. Now the install the new three terminal plug on the 12 volt motor. WARNING: Make sure you connect the positive wire on this motor to the ORANGE wire. Black connects to black. You can now use either motor. No switches needed. Both batteries will be in series for 24 volt operation and your 12 volt motor will run from the first battery in the system.
augnmike
ST, as usual thanks for the detailed description. I will print it out and give it to the tech who will be doing this so I don't mess things up.
Mik, yes I actually have two 12v batts for the TM and one dedicated to just start the boat and work the FF.
