oldjeep
Thread starter- Joined
- May 17, 2010
- 6,455
UPS guy showed up with my replacement trailer tire today, so I grabbed the 5 gallon pail, a long screwdriver and some WD40. Neighbor stops by and is bewildered that I'm actually putting a tire on a rim by myself. Showed him how easy it is to do by setting the rim on the bucket, spraying the beads with the wd40, set the tire on the rim at an angle and jump on it a couple times until it is started then just walk around the tire until the inner bead is on. Repeat with the outer bead and use the screwdriver to pop the last of the bead on. Minute or so on the air compressor and its all done.
Is this really that odd? Can't imagine paying someone $15 for something that I can do in 10 minutes.
