squeaking V6
renny1
just a quick one for my mercruiser 4.3L v6
i have just replace the V belt that goes round the alternator water pump and the balancer and it is still squeaking like mad its not loose and its not the water pump because i spray a bit of wd40 on the alternator wheel and it goes till that dries out,could it be its too tight or is it still too loose
thanks guys
Fishermark
Re: squeaking V6
Why did you replace it? Was the old one worn? Broken? How are the grooves in the pulleys? Shiney and smooth or rusty? I would suggest taking the belt off and examining each pully and component - make sure the bearings are not bad, etc. Also you can check the alignment of the pulleys to make sure nothing is out of whack.
renny1
Re: squeaking V6
the old one was OLD and it finally broke
