Alpha 1 drive wont trim up !
goldens984
:( Need some suggestions . My Alpha 1 drive will trim down but wont trim up . Need to get the boat off the street . I suspect the trim sensor.. the wire is frayed and bare . Any way of jumping the wire to get the trim up ?
Thanks for your suggestions .
Re: Alpha 1 drive wont trim up !
Ayuh,... You should be able to by-pass it inside the transom, at the bullet connectors,...
Follow the wires...
xltier
did u try the trailer switch
goldens984
Bt Doctur ...
Thank You So MUCH ! Made a small jumper cable got the drive to come up .
You saved my weekend !!!! Will be getting those sender switches replaced soon !
