Got hickups!
87turbogn
Yeah, just joined here and was wondering if anyone has a similar problem. I have a 115 hp 2001 Johnson and at WOT it feels like it has the hickups! Between 5 and 10 seconds (and not consistant) it bangs like someone is hitting the back of the boat with a sledge hammer. I first thought it was the prop so I bought a brand new one (not a rebuilt) and it still does it. Now I'm leaning toward the lower unit. Or could the ignition be cutting out for a split second. I can see very fine shiny particles on the magnet but I've seen worse on others. Has anyone ever had this problem?
R.Johnson
Re: Got hickups!
The engine is going in, and out of gear. Gear, clutch dog, linkage.
Faztbullet
Re: Got hickups!
Yep..Better fix it before it gets costly...check the linkage and cable first.
87turbogn
Re: Got hickups!
Yeah, the last thing I did to it last fall was change the controll box because it broke internally. I suppose it wasn't holding it in fwd gear back then. It was banging before the box broke. I even adjusted it favoring fwd gear.
Merc holds their fwd gear with spring tension plus a beveled clutch. It looks like Johnson depends soley on shift cable tension/adjustment to hold it in fwd. Well, I'll pull the guts out, and thank you for the help...it's appreciated!...Keith
