control cables to outboard
siteman44
Hi, I have a Johnson 20hp (1988) that I need to hook the control cables onto. The cables are installed in the shift box already, but I dont know if there is some kind of kit available to connect the throttle and shift cables to the engine. HELP PLEASE !
countvlad
Re: control cables to outboard
there's no kit... the cables, if the correct ones, should connect to the throttle and shift linkage...
siteman44
Thanks Count, however is there not retainer clips with a throttle and linkage attachment for the cables to mount onto the side of the motor and tie into the appropriate controls??
countvlad
do the cables that you have look like this???
siteman44
Yes, but without the ends to connect to the throttle and gear shift, there is nothing beyond the fine adjustment screw
steely51
there are two styles of omc type cables and unless someone has changed something the new style won' work with the new. if the engine end of your cables have just a wire out of the housing you will need to get the ferrels and hardware that attatch to thend of the wire. there is a special way to attatch the ends with the double set screw barrell. tighten one side until contact with the wire, back it off one turn run the other set screw untill contact and then go about one turn more. this will kink the end and make a positive lock a little blue locktight isn't a bad idea .
