1981 150 Evinrude Blown ?
cbcmarine
So all I have a question I had one of my boats on loan and they brought it back possibly ceased. The flywheel will not turn I have checked plugs and they look fine so I am just about to pull the head. I did just rebuild this motor a year and a half ago with a new top end. SO my question is if the bottom end let go would that jam the motor? I can put it in neutral and prop spins and when in gear it does not. This seems to be a motor problem, but before I pull the heads I would like some opinions on the bottom end question
mikesea
Re: 1981 150 Evinrude Blown ?
could be the lower unit as you asked,pull the lower drain plug from the gearcase and see what comes out,if its nice clean oil I think its in the powerhead,if its watery metally gunk,its the lower likely,its very common for lower to lock up powerhead
cbcmarine
Thanks I will check this first thing in the AM
CaptainHook
Did the people who borrowed it give you any indication of what happened? Any noises, alarms, etc????
Did they put the fuel in it when the borrowed it? Did they know it is a 2 stroke?
You never know who knows what about motors.....
cbcmarine
They were idling along so not so bad, no alarms and the gas I mixed before them taking, three tanks for the big guy !!! all on the rich side!
emdsapmgr
Yes, a siezed lower can affect the powerhead. You could actually go further-pull the whole lower unit. If the lower was locked up and you remove it, the engine should fire and run normally (but briefly.)
cbcmarine
So the Bottom end full of water and Oil !!!! DOOOOOO:eek:
top end fine
So does anyone have that part number for that lower end? Am I better to buy aftermarket or start tearing apart and rebuild ?
Thanks
ezeke
Better to find a salvage unit; the salvage yards have them.
sea-way.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
outboardexchange.com
Superior Marine (800-338-9281)
budgetboats.net
americanoutboard.com
piratemarinesalvage.com
trixieslanding.com
mmmarinesalvage.com
cbcmarine
Thanks ezeke, I am in Canada does anyone know of anyone close by to Manitoba?
Thanks
mikesea
EBAY,many years and HP's as long as its a 6 cylinder,but check an interchange chart.Think theres one on IBOATS
bktheking
I'll pm you a guy here in Ottawa who has dozens of lower units for sale, he bought out another marina and they came with the deal.
cbcmarine
Thanks for the help with that
As another question I have been taking the bottom end apart, damn those snap ring's hurt without the right pliers.....
Anyways seems as thought the shaft bearing is ceased, how important are these specialty tools and who carries them other than a dealer
