asdasc
Thread starter- Joined
- Aug 28, 2008
- 681
Hi all,
This weekend I want to replace the fuel lines from the pressure tank to the connector, and then under the cowl from the engine side connector to the carb. I need to know what diameter hose it is. Is it all 5/32?
I plan to use regular automotive store stuff and zip tie it together to get the double hose. The goal is alcohol resistant stuff as I am also rebuilding the carb. The motor is out at the cottage, so I can't just go look.
I am wondering if an auto store will have 5/32, if that is the size. If not, will one of the more common 1/4" or 3/8" hose fit with either enough force, or some hose clamps?
The motor is a 1959 Johnson 18HP.
Thanks,
Thanks,
