mercury 150 stalls at idle only during the hottest part of the day
odom
Engine starts and runs great but during the hottest part of the day it wonts to stall at idle after shut off for a while fishing. If I rev it for a 30/60 seconds then it runs fine. Otherwise, engine is performing perfect. New Thermastats, engine never reads above 150 degrees, good water pressure (Impella good).
Any suggestions?
Thank you
Faztbullet
Re: mercury 150 stalls at idle only during the hottest part of the day
What year engine as the earlier oval style fuel pumps are known for vapor lock.
CDI Tech Support
If all mechanical issues have been ruled out:
Disconnect the idle stabilizer (advance module) and reset the timing between 23-25 degrees Wide Open Throttle. If the problem clears, discard the idle stabilizer as it is not needed.
The Idle Stabilizer was a poor design. No benefit comes from it. When it fails, it can cause problems. It's not needed.
The Idle Stabilizer has three wires:
1. Black
2. White/Black
3. Red/White
The White/Black is connected to White/Black on one switch box.
odom
year 1998 ....
odom
Is there a fuel pump replacement option for my 1998 150 Mercury that could eliminate vapor lock?
Thank you for taking the time to help me.
Faztbullet
The square pump dont lock as much as the oval ones do, install a new diaphram kit with rivets and discard the rubber disc's.
odom
It appears that my diaphram is square....
