First, let me say I've researched this a ton.
Anyway, my 1993 Larson has bottom paint and I hate it. I've been researching methods of removal for months. It seems that the best thing for me to try is going to be a chemical stripper. I will not be paying someone else to do the job.
Im the second owner and the first owner had it painted by a marina and they did a half-assed job (which might actually help with the removal). The surface was not sanded prior to applying the barrier coat. There are some spots on the bottom and on the transom where the paint has come off and its like a brand new gel-coat under there.
The paint is green, I can run my hand over it and it will literally turn green. The paint is chalky and the surface rubs off. The rollers on my trailer have actually turned green with this chalky mess also. I grabbed my pressure washer and went after one spot (about 6"x6") on the hull. With a pressure washer I can actually take all the bottom paint off right down to the barrier coat, which is a goldish color. It takes some time and I have to be real close but it will actually take the paint right off. Does this sound right to you guys? Its just a residential gas pressure washer, 2300 PSI I think.
I was going to try and use kleanstrip's fiberglass aircraft stripper on the paint, but im wondering if I might be better off pressure washing the whole hull down to the barrier coat before trying a chemical stripper? Im guessing I could pressure wash the whole hull down to the barrier coat in about 6 hours. Its a 17 foot boat. Any opinions?
