Hi,
I am working on a Mercury 850 (85HP) 1974. The best information I have gotten from previous owner indicates there no spark on all cyl. After hours of testing and checking all connection, I now have cyl 1 with weak spark, cyl 2 with strong spark, no spark on cyl 3 and completely dead on cyl 4.
Here is some of thing I have already done to the the ignition system. CDI unit was replaced with after market CDI Electronics unit. Trigger unit was also replaced. I have followed CDI's instruction and confirm the CDI unit is putting out big fat spark on its high tension wire to the distributor. Each plug will fire if I manually turn the distributor to each contact, and force CDI to fire by jumping white and brown wire and strike black wire on the motor ground. Still, no spark on cyl 3 and 4. Naturally I suspected the spark plug wire on cyl 4 are at fault. Switch spark plug wire from cyl 2 to cyl4. Still no spark on cyl 4. Cyl 2 still have big fat spark with spark plug wire originally used on cyl 4.
I am guessing the contact point inside distributor cap may have to big of gap of cyl 3 and 4. However, I don't think they are adjustable.
At the point, I am out of idea to try, any comments are welcome.
thanks
thanks
