kayakoc1
Thread starter- Joined
- May 12, 2010
- 2
Boat is 1983.
Mercruiser inline 4, GM 140, SN 6004051
I had the Head reworked 1 season earlier and it ran good, except for a bog (hesitation) on initial throttle up. Next season, I rebuilt the carburetor and it still bogged on inital throttle up, took it to the dealer, who rebuilt carburetor and adjusted valves and it ran good. Next time in the water, the bog was back, so I took it back to the dealer and carburetor was cleaned. During dealer checkout it ran good.
I took it out and it ran good, but during the run, it developed a tick or click (or some type of sound) coming from the engine. I was fairly certain it wasn't some type of valve noise. The head mechanic took it out and thought it might be a piston slapping. I shut it down after this run. This engine has never used oil or even discolored the oil during each season's operation.
I have removed the engine, disassembled and have not noticed any severe looking disorders (severe wear, marks, etc.). I have ( portable drill) honed the cylinders and the only thing that concerns me is a mark on #4 cylinder. I have attached a couple of pics. The plan was to hone the cylinders, go back with new rings, rod bearings and main bearings, however, I'm wondering whether I should take the block to a machine shop and have it honed or bored. The boat is old and not worth that much and I was hoping to do this job on the cheap versus just getting rid of boat with a slight noise in the engine.
In addition, I have found a few chips missing on the gear teeth of the composite/fiber timing gear. (see pic) I'm assuming that this will need replacement. I read in another post to replace both gears, just curious on why. Can the fiber timing gear be pulled and hammered back on without pulling the camshaft? My current puller will not fit the fiber timing gear, does anyone have a suggested tool.
Any comments on using Automotive Parts Store for rings, bearings. I looking for economical pricing. I am also using Mercruiser dealers to price.
Any advice or suggestions will be welcome. I'm somewhat mechanical in nature, however, I'm not an experienced engine mechanic.
Tim
Tim
