Keith7481
- Aug 21, 2005
- 129
Hi folks,
my first year with my boat and I'm attempting to get the antifreeze out of the water tank. I've run the water pump and best it does is to get it down to the last 1 1/2 inches of the pink stuff still in the tank. I can't see a drain anywere on the tank, but haven't crawled to the very stern end to check back there. Is it likely there is a drain back there? If not, are there other ways to get the stuff all the way out of the tank? I was thinking about raising the jack which would move all the fluid toward the stern and the pump outlet line, other than that, I'm clueless. Also, how often should the water separator be changed? Is that a seasonal item, or something done with more frequent use?
Thanks in advance, Keith.
