gas/oil mix
exnavyman123
Re: gas/oil mix
so if i have a 5 gal gas can how much outboard oil do i put with the 5gal. of gas? Also does it matter what oil i use?
Vic.S
Re: gas/oil mix
You should use a TCW3 2stroke outboard engine oil
50:1 is 2.56 fluid ozs per US gallon
so thats 12.8 fl.ozs in 5 US galls .. call it 13 fl.ozs
cajuncook1
Re: gas/oil mix
At at 50:1 ratio of gas to oil
16ounce of oil to 6 gallon of gas = 50:1 ratio (actually it's 48:1) but for simplistic purposes it is 50:1
So each 1 gallon of gas will have 2.67 ounces of oil mixed with it.
A 5 gallon can of gas should have 13.3 ounces of oil mixed with it to have a proper 50:1 gas to oil ratio.
Oil type is TCW-3 2cycle oil (please don't use put the 2cycle oil for chain saws and weed eater)
Good luck my friend!!
cajuncook1
cajuncook1
Re: gas/oil mix
Ha Ha ! I must have been typing the same time as Vic, the wife kept interrupting me.
Listen to Vic, he's got tons of experience;)
cajuncook1
Vic.S
Re: gas/oil mix
If you all listened to me you would forget about ozs and pints and gallons and all work in ccs and litres like the rest of the world. I doesn't half make these calculations easy. ;)
