firsttimeboater04
Thread starter- Joined
- May 15, 2010
- 3
Hi guys, hoping someone can give me some advice.
I am very new to boating (2 days ago)
I bought my first outboard, a 1969 or 1970 evinrude lightwin 4 hp. Problem is, it won't run over 1/4 throttle when there is a load on it. I know this because I broke the shear pin while testing it and then it revved fine. With a load, it runs barely above idle speed. Sounds good, idles good, and I purchased a new Johnson/Evinrude fuel line and have the correct mix of oil and gas (50:1- 1 pint for 6 gallons) The only time I can get it to rev slightly is with the lean/rich knob all the way to lean.
Before I start tearing everything apart, does anyone know where I should start? The last owner rebuilt a lot of the engine; it has new plugs, new wiring, impeller, etc. Any help would be greatly appreciated. I think it's getting way too much gas, but I'm not sure.
Thanks,
Matt
Thanks,
Matt
