What are we trying to accomplish with premium????
There is no reason to run it.
Backwards - the higher the octane, the more resistant to ignition. Old gas is already harder to burn. Stick with the regular your engine was designed for.
only problem i've had with fogging is trying to stall the engine when fogging through the carb. the can just don't introduce enough to stall it. problem cured by filling up a cup with fogging oil and pouring it in. that'll get it to stall.
not dumping it in. pouring it in. some smoke, more smoke, still more smoke till stall.Concentrating that aerosol and then dumping it in, extremely dangerous.
Is it harder to burn even if it's been treated before being put up?
I'm finding my rig runs even more rough at idle than it did last season. Only thing that has changed as far as I can tell is the carb has now been saturated with fogging oil. Next week this carb comes off and a reman goes on. But I'm not so certain that this fall I want someone loading this one up with fogging oil. Hence the question.
Shouldn't be, I put the correct amount of STA-BIL in my tank after my last fall run, then fill the tank with reg. 87 octane to get it good and mixed up, and prep it for winter slumber....
...and don't change the plugs again, that way you won't break one....
