9.5 evenrude help needed
kak630
thanks for looking okay i have a couple of problems 1st one is the point lobe mine was cracked.i have a new one but how far will it go down? and nu 2 i had a water leak it was coming out up by the plate on the recoil where there is a tube for water well there was a piece of round rubber with a o ring in it? what is it should it be there? or did it come from somewhere else? and does any one know where i can get a new gasket, and a new fly wheel key? thanks lots.kevin
ezeke
Re: 9.5 evenrude help needed
The gasket that goes between the engine and the top of the starter is part# 0309696; the flywheel key is 0120395. These are available from any BRP authorized dealership and/or online from boats.net, marineengine.com, ishopmarine.com, maxrules.com, sea-way.com, etc.
The parts catalogs are online at the BRP/Evinrude site: http://shop.evinrude.com/
kak630
thanks a lot do was that piece part of the gasket? it dont look like it would you know. thanks again.kevin
ezeke
Click the thumbnail, please.
kak630
thanks that part is there im wondering if somebody put it in there to try to seal it there were also washers made for under the plate that couldnt have been from the factory. thanks again.kavin
