tinkertinker
- Jun 8, 2007
- 50
I did this test cold, with the other spark plug removed and compression relief disabled... 110 psi and 125psi.
Is this right at the borderline of worrisome? From what I've read, these are decent #s, but a difference this size can be a bad sign.
The plug from the lower compression cylinder looks dark, wet, and dirty. The plug from the higher compression cylinder looks great.
I have a noticeable sheen following me in the water at idle, but have spark in both cylinders. Carb re-build scheduled next, then coils. I don't like this much oil in the water. When I disconnect the fuel line to burn what is left in the lines at the dock, the water discharge looks pretty awful, and white somethings are in the discharge.
