nomorefords
Thread starter- Joined
- May 11, 2010
- 30
As far as I can tell this is a late 60's to mid 70's motor S # is 2477883 I just bought this motor and it seems to run fine and when i 1st started it a lil water came out the pee hole when i replaced the impeller I found 1 of the 3 missing fins the other 2 were nowhere to be found,now no water flow. my thought is that they are lodged somewhere in the cooling system. My question is,,, can the cooling system be either blown out under high pressure, and how or what is the best way to clear it without tearing the engine apart., also gears are stuck in forward,, i can live with that, but would like to fix,, motor wont shut of with the key
I know I'll hear from you wonderful folks soon, and I thank you in advance
Thank you
Doug in Mich
Thank you
Doug in Mich
