1965 9.5 evinrudesportwing problems
rinob44
the motor runs pretty good with out the cover on it but once you put the top on it the motor dies and you have to give it throttle to start it
samo_ott
Re: 1965 9.5 evinrudesportwing problems
There is a common problem on the 9.5 where I believe it's the exhaust gasket that leaks and when the cowling is on it sucks in exhaust in the carb. Search this forum for the exact issue.
kbait
Likely the shift rod seal/bellows is ripped. Not a fun replace, I hear.
rinob44
i took apart the carb and it was as clean as a whistle. the exhaust gasket you are talking about is the exhaust housing gasket i have a parts manual and that was the main gasket i would really aprreacite your help thanks
ezeke
The exhaust relief hose #0309830 at the back of the engine is the worst when it leaks.
Second is the exhaust housing seal #0309729 between the outer cover and the exhaust.
Third is the boot on the shift rod # 0309631.
Fourth is the seal at the top of the water pump #309607 and #309583 which is often missing entirely.
The Exhaust relief hose is fairly straightforward.
Disassembly is required to repair two and three.
You may be able to find three and four at sea-way.com.
rinob44
i ran the motor today without the cover because of the exhaust leaks and it was cutting in and out even at full throttle it took 10 to 15 seconds to go from sputtering to full speed is this part of this exhaust leak thanks
ezeke
If you are running in a bucket it could be. Running on a the water with the cover off, not likely.
rinob44
ok thanks i ran it out on the water so i have a diffferent problem now jthe motor was surging and this was with the cover
off
ezeke
Surging is often from an air leak in the fuel system and can be from incorrect setting of the lean rich needle. Make sure that the high speed jet is clean.
rinob44
when i squeeze the bulb for the fuel till it gets hard and pump it some more fuel leaks from around one of the screws on the fuel pump and from a hole on the carbaurator casing
how to do i check for air and check the high speed jet
