moesislack
Thread starter- Joined
- May 5, 2010
- 21
looking to try dipsy divers for the first time, anybody use these before with success?
I just tried to use some dipsy's today. No matter where I adjusted the weights on them, they wouldn't go out to the side at all. I couldn't get 4' off the side. I'd like to know how to get them 40' out there. I tried the small size and the bigger ones. Neither went out to the side at all. I had a triangular shaped one and the round ones, no difference. I'm just gonna buy some more planer boards and fish that way. I feel I wasted my money buying mine. I tried boat speeds from 1.5-3 mph and these things wouldn't go any further out than my short arm down riggers hanging off the side.
I have not had good luck with any other brand than actual dipsy divers. Did you possibly have them set up backward? With the weight set all the way to one side I have had them a good 50' off the boat to the side. One other thing I forgot to mention if using them for salmon make sure you put a snubber on to avoid break offs.
... Right will dive to your right, and left will dive to your left. A lot of folks running them the first time will switch this because they are usually facing the stern of the boat when setting lines and right and left are switched.
I want to run 2 dipsys on each side.would the deeper running dipsy be towards the bow or should it be the one closer to the stearn?
