Lower unit oil
BassMeister
Why does the lower unit oil have to be put in from the bottom hole instead of the top one on the lower unit? :( 1985 Evinrude. Bassmeister
Brew2
Re: Lower unit oil
If you put it in from the top air would get trapped in the lower unit not allowing it to get full of oil. You would ruin the gears in short order due to lack of lubricant.
By filling from the bottom, the air goes out the top (aka "vent") hole allowing you to get the lower unit full.
F_R
Re: Lower unit oil
You could put it in from the top if you wanted to take all day dribbling it in a drop at a time. Try putting it in faster and it just burps back out at you.
BassMeister
Re: Lower unit oil
Thank you Brew 2 for the simple explanation. That wasnt so complex,lol.
Pass a Brew 2 the crew too
For drink matey is what we do 2...Cheers,BassMeister.:D
Brew2
Re: Lower unit oil
...and a poet to boot.
Cheers.
BassMeister
Re: Lower unit oil
Thank you FR. I noticed that it did just that..burp & spit. It's just a pain,with that palstic bottle I get from Walmart,to fill from bottom. Its like I squeeze and squeeze before anything gets up there. I can go 2 trips, before I have to put more in. Before you ask,I cant, at this time, afford $300 to,I think the mechanic said, get seals/gaskets for water pump.
Thank you so much for the info FR
It has been helpful thus far
This Forum is way above par.
Round for everyone at the bar.;) Cheers. BassMeister
BassMeister
Re: Lower unit oil
Thank you Brew 2 for the observation of my vernacular musings.:rolleyes: I have also been known to drink from the boot,lol :D. BassMeister
Brew2
Re: Lower unit oil
You can get a hand pump that screws onto the bottle top for about $5-$10. Hose from the pump has a fitting that screws into the lower unit fill hole. Virtually no mess except for the bit that comes out between unscrewing the hose and getting the plug back in. (make sure you put the vent plug back in first as the vaccum helps the oil stay in the lower until while you fiddle with getting the drain plug back in).
Can appreciate your frustration at using those "squeezable" bottles for filling the lower unit. What a PITA those are/were.
I get the pumps at a place called "Princess Auto" here in Canada. Don't believe they are in the States, but I'm sure NAPA or some other similar store must sell them.
BassMeister
Re: Lower unit oil
No poem here Brew2. Just a great big THANK YOU. will check this out tomorrow at our local NAPA store. "Oh Canada......." dont know the rest of the anthem,but what I do know is heartfelt. BassMeister
1946Zephyr
Re: Lower unit oil
Oh yea, every marine dealor sells those nice little pumps. I've went through several of them.:D Most places that sell marine supllies will typically sell them too. :cool:
BassMeister
Re: Lower unit oil
Marine dealer suggested by the Zephyr
BassMeister's lower unit gonna purr.
Thank you for the info you ol cur,
Have one on me,cause my eyes are a blur
