Just bought an 86 Johnson 25hp. 1st time out fired up, warmed it up for a couple minutes, and then got up on plane. Everything was right in the world. It started to loose power, and I backed off the throttle and it died. After that, it wouldn't take any throttle. We had to limp back to the launch
Engine would start and idle every time, but if you gave it any gas after it was in gear it would stall. Either I sucked something up into the carb from the old cruise tank, or the fuel pump gave way. (Boat has been sitting for 3 yrs.)
How do you troubleshoot this scenario. Can you test a fuel pump, or do you just "Replace and Pray"? Thanks for the advice in advance. --Overdraw
