Lower Shift Cable
SeattleMatt
i have two dumb questions.
1. Any tricks on how to lubricate a sticky lower shift cable?
2. Is it possible to replace the cable with the boat in the water?
Thanks
achris
More fish than mountain goat
Re: Lower Shift Cable
If it's sticky, there is a reason, usually the upper shift shaft bushing in the bell housing is leaking... And it's not possible to lubricate it.
No....
Chris.
Ayuh,....#1,.. Nope replacement is the Fix...
#2,.. No Way.... The drive,+ gimbel need to come off...
ENSIGN
NO & NO Just bite the bullet buy a lower shift cable kit.Let me know if you have sucess doing it in the water if you dare try!!!
SeattleMatt
Ok, thanks, well that's $500 later to have it hauled out and time to take it all apart. sigh, blows my weekend.
SeattleMatt
I did this job and I wanted to post that it was complete and give some feedback. For the special tool I bought 9/16 "Hollow Shank" driver $12 from my local hardware store. It's designed to go into a drill so I used a small socket on the end with a ratchet, this may not work if your retaining nut is corroded unless you got some big vice grips.
Two parts I found difficult
1. Getting the boot around the flange without removing the gimbal ring is a little tricky. I ended up greasing it a little and spinning it.
2. The plastic seal that goes into the transom clips from the INSIDE, this is impossible as far as I can tell without taking the engine out, so I just slid it on and maybe I'll figure it out another time.
In my kit, Sierra 18-2603, I had another small rubber grommet that I didn't know what to do with (lost the instruction sheet) so I put it on the outside of the transom thinking it is supposed to seal somehow onto the transom seal.
I tightened my cable retaining hex nut down all the way so I am going to pull the drive and loosen it 1/2 turn so the cable can spin freely as noted in the manual.
Anyway, the cable is in and functional, I'm thinking the inner transom seal is going to leak since it's not there but looking at this cheap plastic clip it would probly leak anyway. I don't plan on filling my bilge with water anytime soon and I'm sure I'll be replacing it in 2 years anyway since it's a mercruiser.
