messed up again
ROCKET UT
winterized my 1988 king corbra 460 just like always but this year when putting in the batteries I found three feeeze plugs laying in the motor well
after looking the block three were out and I was missing all three I can get to the front and back but the middle sits just behind the motor mount any ideas besides pulling the motor?
what are the odds of a cracted block?
Lion hunter
Re: messed up again
Chances are good but hopefully the plugs worked as advertised and it didn't. I'd try and suspend the motor (A-frame or cherry picker) and remove the motor mount without a full pull if possible.
ROCKET UT
Re: messed up again
Its a 26 foot bayliner that is about 10 feet off the ground my cherry picker will only go 8 feet.
Just sick about this any one been in the same boat?
Camo Joe
Re: messed up again
Put something under the C picker................
ENSIGN
Re: messed up again
Lay a fence post(steel)across the top of the boat and use a ratchet strap to take the weight off the front mounts, then place some wood blocks under the engine for safety and remove one mount at a time.Those plugs are called coring plugs and were not designed to keep the block from cracking
Re: messed up again
Ayuh,... And Pull the Drive 1st,...
No reason to bend anything,+ it'll need realignment when your done...
zbnutcase
Re: messed up again
Hopefully your manifolds are not cracked as they are NLA!
