Don Peacock
Thread starter- Joined
- Apr 15, 2006
- 12
First the info:
2000 Lund Gran Baron 2150
Mercruiser 5.7L 250hp Alpha one
Current prop: 3 blade aluminum 14.25 / 19P
WOT is about 5100rpm (which is 250-300 over spec).
Max speed (gps) 52mph with medium load, 20gal fuel etc.
I use the 15hp Merc kicker most of the time (trolling for Salmon, Steelhead, Walleye etc.).
On flat to 2' chop, the boat is fine, but once the rollers really start going, I'm unable to push the bow down enough and end up hitting all the waves with the bottom of the boat. I'm not looking to break any speed records, I just want to push the bow down a bit more, 25-30mph with the bow down a couple more degrees would make the boat perfect.
I've looked at trim tabs, but I'd need a jack plate to set the trolling motor back if I were to install trim tabs. Not to mention the issues with transducer location on an aluminum boat, trim tabs would make it even worse.
So, I've been doing a bit of reading about props and have an idea. If I repropped with a 4 blade SS (stiletto 14.25x20P or 14.25x19P) I'd lower my rpm WOT a bit, and get more 'bite' that might let me push the bow down a bit more, wouldn't it?
Looking for some ideas/thoughts.
A couple years ago, I had a 14.25x19P with cupping and it dropped the rpm a bit and seemed to handle a little better. Unfortunately, I hit a stick and took a chunk out of the prop. When it was repaired, it didn't perform nearly as well.
Other info:
This boat has an 80gal fuel tank and when it's full, I am tail heavy. I think the 4 blade will help lift the boat a bit as well on those rare occasions that I have a co-signer with me at the gas station ;-).
Thanks in advance for your thoughts,
Don
Other info:
Don
