familyguy
Thread starter- Joined
- May 30, 2008
- 69
Does this sound like I need to replace the U-joints? I have an SX-M 1.79:1 gear ratio oudrive on my engine. I have had the boat almost 2 years (2nd owner) and for the last 9 months I have noticed a high-pitched whine-almost-grinding sound (it wasn't present the last year and 3 months) come from the rear of the boat only when at WOT and only when trying to make slight adjustments in trim to find the planing sweet spot at this WOT speed. It doesn't happen any other time, i.e. at lower RPMS. A boat mechanic friend said it's the U-joints.
So I figure it's time to pull the vertical outdrive off the pivot housing since this is reccommended annual maintenance anyway and I don't know if it has even ever been done to lubricate the U-joints and drive shaft splines. I'm trying to get all my ducks in a row and have all parts, tools, seals, and gasket sealer in hand before I start so I can knock it out in a day, two at the most with my dad. If it sounds like classic U-joint breakdown I'll just go ahead and shell out the dough for the expensive heavy duty puller ($179) and the U-joints ($42/each) so it's all in hand.
Advice? Any recommedations regarding where to purchase these items? I've done some online searching since the local VP service center is repeatedly dodging my calls about obtaining needed items so I can do it myself.
