I have a 1988 125 HP motor that I rebuilt 3 years ago ( thanks to help from this forum) and mechanically, has been performing flawlessly. Had a few issues with the Prestolite ignition system (Blue coils and CD units). It was a bear to trouble-shoot. Wires everywhere! Plus when I look at all the wires behind the plate that the coils and CD units are mounted on, it looks like a ball of spaghetti! I've tried to straighten them out but it still doesn't look very neat. The CD units were not cheap either!
Anyways, I've always wondered if you could replace the Prestolite system with a late model Mercury Thunder Bolt CDM system that came on the 1996 and later 120 HP motors. Bottom line....yes it can be done! I gathered the necessary parts over the winter on line. Flywheel, stator, trigger, top mounting plate, CDM units with plate. Total cost was about $120 in used parts. Time will tell if it was worth the effort. The CDM units are cheaper and much easier to replace. Don't know if they are more reliable, but I don't see as many posts regarding problems with them. I haven't had a chance to take it out on the water yet, so it's still has not proven itself yet. The fact that the motor even started after the switch is promising.
One other thing I noticed was the NGK BUHX plugs for the Prestolite Ignition system have a gap of about .030, where as the NGK BUHW plugs for the Mercury ignition system have a gap of about .050. Does that mean the Mercury system has a hotter spark?
Before and after pictures.
