Alumarine
- Feb 22, 2005
- 3,762
Hi there. Please bear with me as I'm not exactly sure what I'm talking about.
I have a Merc 50 Serial no. 6097907 I think it's an 82.
This motor came with Power Trim but no pump.
I picked up a Mercruiser pump and am having trouble getting the hoses figured out.
The rams have 2 hoses each with what I would call brake line fittings.
The pump has one port that uses the brake fitting (I'm assuming that's the high pressure)
and a port that uses a larger compression style fitting with a clear plastic tube.
I have a mercruiser rmanifold that will take the lines from the Rams and one of the lines from the pump.
How do I or what do I need to get a line from the low pressure port on the pump to the manifold?
Sorry if this is confusing but it's the best I can do right now. I'll try and get pics.
