Should I get my tires balanced on my boat trailer?
cullen493
I was just wondering if it would be a good idea to get my trailer tires balanced? What kind of place would I take it to like just a regular tire place or someone that specializes in trailers.
lime4x4
Re: Should I get my tires balanced on my boat trailer?
Any tire shop can balance a trailer tire
mphy98
all tires should be balanced. It is like a hard spot on the tire getting slapped every rotation when not in balance. It is a cheap away to make your tires last longer and have no problems with tire slap.
jeffw0038
Yep i would do it either way. especially so if you haul it any distance
Gary H NC
Agree...... Tires will wear better and less stress on the suspension.
kenmyfam
Well worth the few bucks to balance them.
seaboo
Yes you should do it (huge difference). I balance all my tires (even the 8" ones on my jet ski trailer), I use to haul to the beach alot (about 300 miles) and it does make a difference.
JimMH
I always get mine balanced. It is a much smoother ride and tire wear is even.
Dodger1234
Good topic and good advice!
Dodger.
Thundra
If you don't balance the wheels/tires, try towing the trailer and see/feel what it is like.
I had gotten a new trailer and when I got on the highway, my entire truck was shaking and the trailer was about bouncing up and down on the road. I promptly stopped at the first tire shop and they balanced all 4 wheels and the problem was solved.
As my tires started to wear, I noticed one of my fenders on the trailer shaking during a certain speed. New tires and a balancing and everything was smooth again.
No doubt that balancing has to be done. Most of the vibration gets masked from the boat/trailer suspension and its isolation from the tow vehicle but imagine what the imbalance must do to the bearings et-al.
smokeonthewater
I have never had any trailer tire balanced and have no intention of starting
I have never noticed any vibration either but then my trailers are much heavier (6-10k) than many... It is probably a good idea but isn't always absolutely mandatory
