Johnson 1970, 85 hp with spark on 2 at start, but no more spark.
burnie
First off, this is a great site. I have used it from time to time with great results. I have searched before hand to see if my problem has been posted. It has not quite been asked, so here is my question; I have a 1970, Johnson 85 hp 4 cylinder. The motor was running last year when it died on me. It died several times while running. It would reluctantly start off and on. I took it home, where it would start, then die right away. It eventually quite starting all together. I tested spark on all the plugs. I would get sporadic spark on random plugs. No real rhyme or reason for it, but not good enough to get the motor running. I tested the amplifier with the light bulb trick, It is ok. I went ahead and replaced the coil, in fear of blowing the amp. Still no real spark. Now, the only spark I get is on plug 2 and it is only one spark upon first crank of the motor. No other plug has any spark at all. Any suggestions on the next step.
Thanks in advance.
David
burnie
Re: Johnson 1970, 85 hp with spark on 2 at start, but no more spark.
I forgot to mention, Ill be pulling the flywheel this afternoon to check for crud under the distributor cap.
burnie
ttt
burnie
ttt
burnie
Nothing??
burnie
Found the problem and will post what I found so that it might help someone in the future. Once I found my fly wheel puller, I pulled the fly wheel and started inspecting everything. I found two problems. First was the wire comeing from the amplifier to the points. I had wore away by the clamp. I replaced the wire, checked the points and cleaned them up.
Second problem; The distributer had a small crack on the inside. It had show some burn marks comeing from the crack. I could bearly see it. I replaced the distributer (thank goodness I had one lying around), put her all back together and she is working like a champ.
RichardNaugle
Hi burnie thanks for the info. I am currently having the same problem with mine and I'm going out to pull the flywheel now ..thanks.
