Re: 1972 evinrude 85hp points question
The power to the amplifier comes from the ignition switch. The breaker points just tells it when to discharge through the coil.
By bulb test, you mean at the coil wire? The points are working if so. That doesn't mean they are firing each and every time, or gapped correctly though.
